08 lmm completely stock with original parts. No tuners and a dpf system. Please no chokes about it being stock and no tuners and still having a dpf. It out pulled most fords and doges up jelico mountains pulling 36' toyhauler. So I'm please with my stock truck. Went from 13 mpg hauling and 22 mpg empty to 17mpg empty and 7-9 mpg hauling toyhauler. Sometimes you here turbo other times when ya kick it down for interstate it sounds like a quadrajet opening up. It was knocking or rattleing (sounds like lose valvetrain on gas engine) 1800-2000rpm and while dpf cycled then when done noise was gone. Dpf cycles about every 350 miles or tank and half. Dealer found problem with turbo and possible ecm. When i took it back for recheck no issues found or stored codes either time. When real hot pulling then stop and idle cant feel exhaust or hear turbo. When cold feel exhaust and hear turbo. Then the other day after it got good and warmed drove to moms farm hard let it idle and first time feel alittle exhaust flow. Totally confused with problems and no codes. Oh also dealer checked injector ratiios, fuel pressure, dpf soot level. All real good for 113k on truck. Is this a vane problem, vane sensor, or the ring cracked in turbo I've been reading about in forums. Yes i have read alot first diesel. Thanks for any input. Also is the vane sensor for $500 from dealer same as the $99 from diesel care?
Power issue no codes
Originally posted by Duramax798308 lmm completely stock with original parts. No tuners and a dpf system. Please no chokes about it being stock and no tuners and still having a dpf. It out pulled most fords and doges up jelico mountains pulling 36' toyhauler. So I'm please with my stock truck. Went from 13 mpg hauling and 22 mpg empty to 17mpg empty and 7-9 mpg hauling toyhauler. Sometimes you here turbo other times when ya kick it down for interstate it sounds like a quadrajet opening up. It was knocking or rattleing (sounds like lose valvetrain on gas engine) 1800-2000rpm and while dpf cycled then when done noise was gone. Dpf cycles about every 350 miles or tank and half. Dealer found problem with turbo and possible ecm. When i took it back for recheck no issues found or stored codes either time. When real hot pulling then stop and idle cant feel exhaust or hear turbo. When cold feel exhaust and hear turbo. Then the other day after it got good and warmed drove to moms farm hard let it idle and first time feel alittle exhaust flow. Totally confused with problems and no codes. Oh also dealer checked injector ratiios, fuel pressure, dpf soot level. All real good for 113k on truck. Is this a vane problem, vane sensor, or the ring cracked in turbo I've been reading about in forums. Yes i have read alot first diesel. Thanks for any input. Also is the vane sensor for $500 from dealer same as the $99 from diesel care?
Sent from my SAMSUNG-SM-G891A using Tapatalk
Ok finally i get to answer. Thank you for the suggestions. No o e on duramax diesel would comment but be rude about my dpf on it. Question if parts broke off and caused a restriction(more backpressure) why are there no codes? Youd think there would be a code. Is it normal to hear a "pink" under truck where CAN and DPF filter is after ya shut the truck when put in park..also with variable vane turbo do ya have to cool down pulling or normal driving for exhaust temps to come down or not. Heard both way. Wish they had a place like this in Southern Indiana. I'd take my truck there instead of dealers. Agsin thanks for the help.
Mike D had something from ultra gage to monitor but blue tooth sucked. Also never monitored dpf. Had turbo boost(good 22lbs then level off to 2 to3lbs) fuel pressure(good) injectors(good) exhaust temp was Cat before and after(1600 f with dpf) cant remember normal range. Engine temp was 198 pulling but dash gage said 245.
Mike D had something from ultra gage to monitor but blue tooth sucked. Also never monitored dpf. Had turbo boost(good 22lbs then level off to 2 to3lbs) fuel pressure(good) injectors(good) exhaust temp was Cat before and after(1600 f with dpf) cant remember normal range. Engine temp was 198 pulling but dash gage said 245. Insight yes that would be nice and on list after paying hospital bills off. Bills first fun stuff later. But i know kit would give you diesel guys what ya know to tell me whats happening. Do not want or need a tuner dont like black smoke. Hate that when on the harley, tbink its rude a wasting fuel. Try to get more info for ya and DMAXDR.
Originally posted by Duramax7983Mike D had something from ultra gage to monitor but blue tooth sucked. Also never monitored dpf. Had turbo boost(good 22lbs then level off to 2 to3lbs) fuel pressure(good) injectors(good) exhaust temp was Cat before and after(1600 f with dpf) cant remember normal range. Engine temp was 198 pulling but dash gage said 245. Insight yes that would be nice and on list after paying hospital bills off. Bills first fun stuff later. But i know kit would give you diesel guys what ya know to tell me whats happening. Do not want or need a tuner dont like black smoke. Hate that when on the harley, tbink its rude a wasting fuel. Try to get more info for ya and DMAXDR.
Last edited by DmaxStoreJimmy; 04-12-2018, 07:00 PM.2006 LBZ Daily Driver, Tractor, School Bus, Hot Rod Diesel , Crew Cab, Lifted, Hunting Rig , Cowboy Cadillac
