2005 LLY allison range shift inhibited
  • #31
    No problem. Everything actually looks normal except for the filter just falling out when I dropped the pan. If that filter wasn't seating properly would that not cause vacuum problems?
    Sent from my SM-G935V using Tapatalk
    • #32
      My measurements seems to be exact to what you have on that pan
      • #33
        Yes your pan looks stock. Sounds like you have called in and talked with our service manager Chad. You told him the truck drove fine for a couple days then started shifting weird.
        Looks like some better diagnostic is needed. Did you make an appointment to bring it in?
        • #34
          No not yet Mike. I just closed it back up. I am a little short on fluid now but man she does not want to go in R. One thing I have noticed is the PRND123 display is really dim. I can't see what gear it goes into at day time. Is this a sign that the amperage may be low to the trany
          • #35
            I appreciate all the replies today. I am a little frustrated with this truck right no. I just last month had to replace the water pump and now this. This truck is my daily commuter to and from work so I need to figure it out soon.
            • #36
              Try eliminating the Banks tuner. Also consider putting your original NSBU switch back in since the problem is getting worse with the new one installed.
              • #37
                Will do that tomorrow. You guys carry the factory NSBU part or is that dealer only
                • #38
                  Chad also mentioned that it could be my ignition switch
                  • #39
                    We carry and instal original Allison brand.
                    • #40
                      I just browsed your website. Very nice and the price is competitive. Will have to stop by and meet you guys.
                      Thanks again for all your input.
                      • #41
                        Please do, though we wish it were under better circumstances. Just a FYI, tomorrow we are closing early (1:30pm)....
                        • #42
                          Hey Mike how big of a job is the ignition switch. I am going to replace that today.
                          After that fails I will put back the old NSBU and see if it acts different. If all the above fails I will have to schedule an appointment with you guys
                          • #43
                            Update I fixed my problem. Came down to a 33 dollar ignition switch and it took me about a half hour tops to swap it out.
                            That ignition switch can be the cause of a lot of trouble with the allison.
                            • #44
                              Glad you got it figured out!
                              • #45
                                Good deal. Chad said he talked with you on the phone and thought that might be the source of your issue. 👍
