Some before and after pics of the Duramax GMTK2XX trucks powered by those LML and L5P powerplants.
2015-2019 Sierra and Silverados
Lift: Cognito 4-6" NTBD
Wheel: Fuel Cleaver (D574)
Tire: Nitto Ridge Grappler 35x12.50R20
Before:
After:
New body style LML.
Lift: Kryptonite Stage 3 leveling kit
Wheels: OEM
Tires: OEM
Before:
After:
Lift: BDS 6.5" Coilover
Wheel: Fuel Maverick D260 20x10
Wheel: Hostile Sprocket 22"x12"
Tire: Toyo Open Country ATII 33x12.50R22LT
Others: Kryptonite Tie Rods, Kryptonite Bolt in Upper Ball Joints, Fox 2.0 Resi shocks, and FTS Resi Mounts.
Originally posted by DmaxStoreJake View PostGive us a call for all your Duramax needs! 877-469-3629
Check out this L5P that we did a leveling kit on awhile back. This one is a little different from your typical leveling setup. Typical leveling setups just raise the front to match the rear. On this specific setup, our customer wanted to bring the front up just a hair and drop the rear. This leveling combination created a nice level look with an awesome ride quality versus just cranking up the stock torsion keys. Best of all this leveling setup and wheel/tire combo did not require cutting/trimming and DOES NOT rub!
Here are the parts that were used on this beautiful L5P:
-DmaxStore Stage 3 Leveling Kit(Kryptonite Upper Control Arm Kit, Kryptonite Torsion Keys, and Bilstein Shocks) (set at approx. 1.5" higher than stock)
-McGaughys Drop Shackles(set at 2" drop)
- 20x9 +18 offset SOTA SPYK Wheels
- LT285/60R20(33.7") Nitto Ridge Grapplers
