2015-2019 Sierra and Silverados
  • 2015-2019 Sierra and Silverados
    Some before and after pics of the Duramax GMTK2XX trucks powered by those LML and L5P powerplants.
    Lift: Cognito 4-6" NTBD
    Wheel: Fuel Maverick (D538) 20x8.25
    Tire: Nitto Trail Grappler MT 35x12.50R20
    Before:
    After:
      Wheel: Fuel Cleaver (D574)
      Tire: Nitto Ridge Grappler 35x12.50R20
      Before:
      After:
        New body style LML.
        Lift: Kryptonite Stage 3 leveling kit
        Wheels: OEM
        Tires: OEM
        Before:
        After:
          Lift: Cognito 10-12"
          Wheel: American Force 26" 6G17 Evo
          Tire: Fury Country Hunter MT 40x13.50R26
            Lift: BDS 6.5" Coilover
            Wheel: Fuel Maverick D260 20x10
              Wheel: KMC XD 834 Cyclone 20x10
              Tire: Nitto Ridge Grappler 33x11.50R20
                Wheel: Fuel Krank (D517)
                Tire: Nitto Ridge Grappler 295/60R20
                  Leveling Kit: Kryptonite Stage 3 leveling kit With Bilstein 5100 Shocks
                  Wheel: Stock
                  Tire: Stock
ID:	5105Click image for larger version
ID:	5104Click image for larger version
ID:	5103Click image for larger version
ID:	5102Click image for larger version
                    Wheel: Hostile Sprocket 22"x12"
                    Tire: Toyo Open Country ATII 33x12.50R22LT
                    Others: Kryptonite Tie Rods, Kryptonite Bolt in Upper Ball Joints, Fox 2.0 Resi shocks, and FTS Resi Mounts.
                    Click image for larger version  Name:	Front quarter b roll after-1.jpg Views:	1 Size:	136.8 KB ID:	5166
                    Click image for larger version  Name:	after -2.png Views:	1 Size:	838.7 KB ID:	5167
                    Click image for larger version  Name:	IMG_5332.jpg Views:	2 Size:	185.6 KB ID:	5172
                      Lift: BDS 6.5" Lift
                      Wheel: Moto Metal 20"
                      Tire: Toyo Open Country ATII 35x12.50x20LT
                      Others: Kryptonite Tie Rods, Kryptonite Bolt in Upper Ball Joints, Fox 2.0 Resi shocks, F TS Resi Mounts, Airlift Wireless Controller, Pacbrake Airbags, BDS Recoil Traction Bars.
Name:	before and after.jpg
ID:	5232Click image for larger version
ID:	5233Click image for larger version
                        Lift: Cognito 4" Lift
                        Wheel: American Force 22"
                        Tire: Nitto Ridge Grapplers 33x12.5
                        Others: Kryptonite Tie Rods, Kryptonite UCA's, Fox 2.0 Resi Shocks, FTS Resi Mounts. Click image for larger version
ID:	5238Click image for larger version
ID:	5237Click image for larger version
ID:	5236Click image for larger version
                          That is a good looking truck!
                            Lift: CST 3-6" Lift
                            Wheel: Method 18" Wheels
                            Tire: Toyo Open Country M/T 35x12.50R18LT
                            Others: Kryptonite Tie Rods, Kryptonite UCA's, Bilstein 5100 series shocksClick image for larger version
ID:	5245Click image for larger version
ID:	5243Click image for larger version
ID:	5244Click image for larger version
ID:	5246Click image for larger version
ID:	5248Click image for larger version
                              Check out this L5P that we did a leveling kit on awhile back. This one is a little different from your typical leveling setup. Typical leveling setups just raise the front to match the rear. On this specific setup, our customer wanted to bring the front up just a hair and drop the rear. This leveling combination created a nice level look with an awesome ride quality versus just cranking up the stock torsion keys. Best of all this leveling setup and wheel/tire combo did not require cutting/trimming and DOES NOT rub!
                              Here are the parts that were used on this beautiful L5P:
                              -DmaxStore Stage 3 Leveling Kit(Kryptonite Upper Control Arm Kit, Kryptonite Torsion Keys, and Bilstein Shocks) (set at approx. 1.5" higher than stock)
                              -McGaughys Drop Shackles(set at 2" drop)
                              - 20x9 +18 offset SOTA SPYK Wheels
                              - LT285/60R20(33.7") Nitto Ridge Grapplers
Name:
ID:	5268 Click image for larger version
Name:
ID:	5271 Click image for larger version
Name:
ID:	5269 Click image for larger version
Name:
