DMAXSTORE Service Facility
  • Hope I get my studs and Head gaskets done before I have problems like all the other LLY's.
    • Originally posted by Widebody04 View Post
      well, just keep praying to those DMAX Gods my friend
      • If mine go, the limo will be sitting for a long time. Oh dear god! Lol
        • staying busy
          in need of a diagnostic run through
          Click image for larger version
          In need of some draining, seems the rough running and stumbling DMAX does not operate too well with Gasoline in her tank!
          Little AD install on a customers rig
          getting a stock replacement turbo installed, cant use the lift cause of the truck weight, so this may be a knuckle buster, Lol
          Few other routine maintenance jobs going on and diagnostics
          • Guys are doing a little Christmas Shopping.. Lol
            This truck was having a strong odor of exhaust during regin, so a new updated gasket was installed between the down pipe and CAT, No more smell
            This truck has a cracked rear T-Case housing, getting the new housing
            Another one on the flat bed, second in 2 days
            • Click image for larger version
              And yesterdays delivery
              Customer had a ECM failure while uploading his PPE tuner... We will get him back up and running
              • few things happening
                Finished up another head gasket job
                New fox shocks
                And this bad boy built motor for the race truck
                • sure makes it hard to get the pics and updates up when its pretty much been raining...
                  But lets get back to it.
                  Customers truck, got some head studs, gaskets, Cognito control arms, Kryptonite rear case, DMAXSTORE Built trans, Kryptonite T-Case brace
                  • a little more
                    little inspection and fluid changes
                    • Getting back to business after some Holiday CHEER!
                      Customer in need of Injectors and head gaskets
                      Also, customer who was running some wires for a device through the grommet , ended up doing some damage to some vital wires that made the truck not run. Just be really careful when running wires through the grommet and do not use any sharp tools to pock holes and or use to fish the wires through to the inside of the cab from the firewall.
                      the vital wires that were damaged
                      No worries we will have this baby running with no interruptions shortly .
                      • Another cold day in the foothills
                        Customer in with a clean DMAX getting a titan tank and a Fleece Tap Shifter installed
                        • This customer is in for a oil leak, need to find out its origin and go from there
                          The truck yesterday posted above with the gnarly bumper in need of HG and injectors, progress for sure...
                          • So the truck above getting the work done, all cleaned up, inspected and awaiting parts to re assemble.
                            • routine service and inspection
                              another injector job
                              • This truck is in need if upper and lower ball joints
                                Elected to do go with the DMAX HD UCA's ans the kryptonite lower ball joints
