2004 UCA
  • 2004 UCA
    I have a question for you. I have cognito UCA's they will not let me drop torsion bars down all the way and still have camber adjustment to bring tires straight. I have moved the ball from bottom to top which helped. Come to find out they are about 3/4 of inch longer than stock. I was looking at doing your moog arms. How does the Kryptonite measure up, same length as stock or are they a little long as well. Now I'll add that I'm still have my tuff country 6in lift on. But have gone to a 33 tire and 2in blocks in the back and lowered the bars as far as I could for now?
    If your lift kit runs in a very relaxed setting most of the time. You will want an OE style control arm like the Moog or XD. Cognito and Kryptonite are designed for leveled and lifted applications.
      Thanks Mike That's what I thought, but had to ask.
        Now the Kryptonite lower arms are they only for leveled or lifted as well?
          The lowers can be run in any configuration. They do not effect or change geometry, just look awesome, cut weight and ad strength.
            That's good to know. I ordered the XD uca's and drop shackles today I hope that gets me down where I need to be for the strip. Still trying to keep a little height to sled pull. I know sooner or later I'll have to build two trucks. Thanks
              guess I better put a picture of them here as well.
                I have the Kryptonite Arms on my 4 inch lift. They are definitely designed for more droop.
                  The cognitos just couldn't get low enough.
