DmaxStore High Capacity Transmission Pan
Fits 2001-2019 Chevy/GMC 2500/3500HD trucks with the Allison 1000 Transmission
Part# DMAX-TP-0119
Introducing the DmaxStore High Capacity Transmission Pan, the perfect upgrade for your Allison 1000. Engineered with top-notch features, this transmission pan is designed to enhance cooling, improve performance, and ensure longevity of your Allison. Cast out of durable aluminum, this transmission pan is built to withstand the toughest conditions while providing superior cooling capabilities. The cast aluminum construction dissipates heat more efficiently than the OEM material, effectively reducing operating temperatures and extending the life of your transmission. With its premium textured black powdercoat finish, the DmaxStore High Capacity Transmission Pan not only looks sleek and stylish, but it also offers added protection against corrosion and wear. One of the standout features of this transmission pan is its increased fluid capacity. This pan has a fluid capacity of an additional 1.35 gallons vs OEM which allows for better heat dissipation to help prevent overheating. The internal rib design of the DmaxStore High Capacity Transmission Pan serves multiple purposes. It reduces fluid sloshing, preventing aeration and ensuring consistent lubrication throughout your transmission. Additionally, the Internal and External ribs maximize the surface area for improved cooling efficiency and strength. The DmaxStore High Capacity Transmission Pan comes complete with an oversized magnetic drain plug, facilitating quick and hassle-free services. The magnetic drain plug efficiently captures metal particles, preventing them from circulating through the transmission system and potentially causing damage.
Part# DMAX-TP-0119
- Cast aluminum construction with cooling fins for better heat dissipation
- 1.35 Gallons of added Fluid Capacity over the stock pan for increased cooling
- Built in filter lock to keep your internal filter in place
- Textured Black powdercoat finish
- Oversized Magnetic Drain Plug for hassle free oil changes
- Port for additional oil temperature sensor (sold separately)
- Overall Height 5.95 in.
- 1x DmaxStore High Capacity Transmission Pan
- 1x Oversized Magnetic Oil Drain Plug
- 12x Pan Bolts and Washers
- 1x Brass Plug for the temperature sensor port
