DmaxStore LB7 Stainless Steel Injector Cups
  • DmaxStore LB7 Stainless Steel Injector Cups
    DmaxStore Stainless Steel LB7 Injector Cup Replacement Set
    Part# DMAX-IC-LB7-SET
    Replaces GM part# 97188463
    Replace your damaged or worn injector cups with our BRAND NEW DmaxStore LB7 replacement injector cup set. Don't waste time cleaning the original cups or run the risk of leaks with a refurbished cup. These are made out of 304 Stainless Steel locally right here in small town USA!
    • (8) DmaxStore LB7 injector cups
    • (16) Cup O-Rings
    Click image for larger version  Name:	_MG_0287-700x700.jpg Views:	1 Size:	43.8 KB ID:	6031
    Click image for larger version  Name:	_MG_0297-Edit-Edit-700x700.jpg Views:	1 Size:	62.4 KB ID:	6032
    Click image for larger version  Name:	_MG_0295-700x700.jpg Views:	1 Size:	69.0 KB ID:	6033
    Click image for larger version  Name:	_MG_0301-700x700.jpg Views:	1 Size:	49.2 KB ID:	6034
    DmaxStore Stainless Steel LB7 Injector Cup Replacement Set Part# DMAX-IC-LB7-SET Replaces GM part# 97188463 Replace your damaged or worn injector cups with our BRAND NEW DmaxStore LB7 replacement injector cup set. Don't waste time cleaning the original cups or run the risk of leaks with a refurbished cup. These are mad
