Dmax XD Tubular Upper Control Arm Kit
  • Dmax XD Tubular Upper Control Arm Kit
    Click image for larger version  Name:	dmax xd tubular arms-1-700x700.jpg Views:	1 Size:	47.3 KB ID:	5946
    https://dmaxstore.com/collections/al...-kit-2001-2010
    These DMAX XD Tubular Upper Control Arms are the perfect upgrade for any truck owner looking for for a better ride or just that badass tube style control arm look. The gusseted tube design makes them extremely sturdy for any towing or off-road use. The ball joint angle is similar to OE which makes these arms perfect for most stock, lifted, and lowered applications that utilize the stock control arms. The included Dmax XD bolt in ball joint is stronger than factory and is designed with a higher articulation range to withstand harsh environments and road conditions.
    Click image for larger version  Name:	dmax xd tubular arms-3-700x700.jpg Views:	1 Size:	53.9 KB ID:	5947 Click image for larger version  Name:	dmax xd tubular arms-5-700x700.jpg Views:	1 Size:	52.7 KB ID:	5948 Click image for larger version  Name:	dmax xd tubular arms-7-700x700.jpg Views:	1 Size:	43.1 KB ID:	5949 Click image for larger version  Name:	dmax xd tubular arms-11-700x700.JPG Views:	1 Size:	99.3 KB ID:	5950
    • Sleek Tube Style Arm with Black Powder coating
    • Xtreme Duty Tubular Design with a Medial Gusset for Increased Strength
    • Increased Ball Joint Range of Articulation allows for Longer Life and Peace of Mind
    • Dmax XD Bolt in Ball joint for easier replacement if needed
    • Serviceable Polyurethane Bushings
    • 2 x DMAX XD Tubular Upper Control Arms (For BOTH Sides)
      • Includes all bushings, Bolt in Ball Joints and hardware for installation.
    (Dmax XD Warranty) Dmaxstore XD Steering and suspension parts come with a 3 year unlimited mileage warranty to the original purchaser. Warranty period begins at date of purchase. If a failure occurs, Dmaxstore will replace the failed part only once it has been received at our facility. Shipping costs are not included under the warranty.
