Kryptonite Death Grip Full Floating Traction Bar Kit (2001-2010 ECLB & CCSB)
  • Kryptonite Death Grip Full Floating Traction Bar Kit (2001-2010 ECLB & CCSB)
    Kryptonite's new Death Grip Full Floating Traction Bar Kit will completely eliminate axle wrap and wheel hop. These are major issues even on stock trucks. This Traction bar system is the solution to getting power to the ground efficiently while also maintaining a comfortable ride down the road. Most other traction bar kits on the market solid mount your rear axle to the frame mounted bracket. This creates an enormous amount of road feel and vibration in the cab as well as more stress on your rear drivetrain components.
    The new Death Grip Full Floating Traction bars are the solution. Our system locks the rear axle in place under high torque events that causes axle rotation; (Flooring it under load) But during normal driving the rear axle can move freely through its range of suspension travel making for a comfortable ride.
    Engineered exclusively for the Extreme demands of today's Heavy Duty Truck. Built with pride in the USA to work with stock or modified suspension. Kryptonite Death Grip Full Floating Traction Bar Kit will fit any 2001-2010 2500/3500HD Chevy/GMC 2500/3500 HD Ext Cab Long Bed & Crew Cab Short Bed Trucks 0"-6" Lift.
    https://dmaxstore.com/collections/al...-kit-2001-2010
    Click image for larger version  Name:	KRTRB10-700x700.jpg Views:	1 Size:	64.0 KB ID:	5778
    • Heavy Wall DOM Tubing
    • Grade 8 Hardware
    • Heavy Duty Precision Cut Bracketry
    • Serviceable Grease Ports
    • Improved Strength and Rigidity
    • Easy Installation
    • No Special Tool required
    • Direct Bolt on Replacement, Drilling Required for Frame Brackets
    • Made in the USA
    Click image for larger version  Name:	Artboard1_1024x1024-700x700.jpg Views:	1 Size:	87.6 KB ID:	5779
    Click image for larger version  Name:	Artboard2_1024x1024-700x700.jpg Views:	1 Size:	80.6 KB ID:	5780
    Click image for larger version  Name:	Artboard3_1024x1024-700x700.jpg Views:	1 Size:	84.3 KB ID:	5781
