Edge Insight CTS3 Now Available and Shipping!!
  • Edge Insight CTS3 Now Available and Shipping!!
    The long awaited Edge Insight CTS3 is finally available!!
    Click image for larger version  Name:	InsightCTS3_Splash.jpg Views:	1 Size:	74.2 KB ID:	5558
    Observe and understand your vehicle parameters using Edge state-of-the-art technology. Our Insight CTS3 delivers unmatched monitoring capability for any OBDII vehicle (1996 or newer). This digital gauge display works well with custom tuning products or as a stand-alone monitor for total insight on how your vehicle is performing.
    The Insight is the #1 preferred digital gauge monitor in the market today, used by daily drivers and enthusiasts everywhere. The Insight is the most comprehensive, state-of-the-art, multi-gauge touch-screen display on the market. It is an instantaneous and inexpensive alternative to bulky, analog gauges that would otherwise cost hundreds of dollars and take hours to install. This is the perfect tool for those who want to monitor their vehicle's performance and prefer not to program their vehicle, or for those who already have significant performance upgrades and want to safely monitor their vehicle's performance. Not only can the Insight monitor vehicle performance, but it can also be intelligently configured to provide audible and visual alerts to help you protect your vehicle.
    Insight CTS3 Features:
    • 5 full color, high-resolution, swipe screen
    • Custom color mixer for gauge arcs, needles, and backgrounds
    • Multiple gauge screen layouts
    • Fully customizable backgrounds
    • HDMI style plug for power and linking EAS accessories
    • One-touch easy menu navigation
    • Notification center
    • Available for 1996 and vehicles equipped with an OBDII (diagnostic) port
    • Switch between US or Metric units of measure
    • Comprehensive digital gauge display
    • Available for 1996 and newer vehicles equipped with an OBDII port
    • Compatible with other tuning devices
    • Displays dozens of parameters
    • Integrated accessory system for additional gauges or can control switches for lighting, compressors, winch, etc.
    • Advanced integrated data logger with export capability
    • Light sensitivity meter to dim screen as ambient light decreases
    • Internet Updatable
    *Some features may vary by make/model/year.
    Data Parameters:
    • Accel Pedal Position,
    • Ambient Air Temp
    • Barometric Pressure
    • Battery Voltage
    • Corrected Speed
    • Desired FRP
    • Desired Idle RPM
    • Distance Code Cleared
    • Distance Since Regen
    • EGT Exhaust Manifold
    • EGT1 Post Turbo
    • EGT2 Post CCDOC/Pre SCR
    • EGT3 Post SCR/Pre DPFDOC
    • EGT4 Post DPFDOC/Pre DPF
    • EGT5 Post DPF
    • Engine Coolant Temp
    • Engine Load
    • Engine RPM
    • Engine Run Time
    • Fuel Pressure
    • Fuel Rail Pressure
    • Fuel Temperature
    • G Force
    • Gear & TCL
    • Horse Power
    • Intake Air Temp Manifold
    • Main Injection Timing
    • Manifold Abs Pressure
    • Mass Air Flow
    • Mileage Average
    • Mileage Coach
    • Mileage Instant
    • Percent Grade
    • Regen Status
    • Regeneration Reason
    • Run Time
    • Start Up Intake Air Temp
    • Time 0 to 60
    • Time Quarter Mile
    • Torque
    • Trans Fluid Temp
    • Trip Odometer
    • Turbo Boost
    • Turbo Vane Position
    • Soot Accumulation percent
    • Urea Fluid Temp
    • Urea Pressure
    • Vehicle Speed
    • Warm Ups W/out Emissions Malfunction
    • Warm Ups W/out Non Emission Malfunction
    *To use a backup camera on the Insight CTS3 a new adaptor will be needed. CTS3 camera adaptor will be released soon.
    Exclusive Technology Not Available Anywhere Else!
    Edge has raised the bar again with the innovative features in the CTS3 screen that are not found in similar tuners/monitors
    • Razor thin display integrates into your cab seamlessly unlike other bulky monitors and busy gauge clusters.
    • 5” HD screen, the largest available on the market, accommodates up to multiple colors and clocks at a faster frame rate than competing monitors.
    • Proprietary one-touch navigation menu. Seamlessly swipe through data and check alerts with the most intuitive and improved user interface ever designed for a truck programmer/monitor
    • One HDMI cable to power the monitor and link your EAS accessories as opposed to multiple inputs and bulkier cables that come standard on other devices.
    • Day or night with Edge’s built in light sensitivity meter your monitor will adjust the brightness giving you the ideal brightness while driving.
    Take Performance to the Next Level!
    Edge has been and still is the king of truck performance and monitoring. We increase the maximum exposure of your engine while simultaneously monitoring parameters for alerts to improve your overall driving experience.
    • Multiple shift-on-the-fly performance tuning settings with EAS and serial to control power and control for any situation.
    • Log, graph, and export hundreds of parameter to track or improve performance
    • Test and track performance runs such as 0-60mph, and ¼ mile
    Customize it and Make it Your Own!
    Everyone’s needs are different. Whether you are using your truck for work, pleasure, or competition – no other vehicle monitoring system gives you more customization options than Edge!
    • Display hundreds of different combinations of gauges in digital or analog format in Metric or US units
    • Set audible & visual alert notifications when certain parameters or temperatures are met
    • Adjust the background screen, gauge arcs, keylines, and needles to virtually any color to make it your own or match your vehicle’s interior.
    • EAS (Expandable Accessory System) compatible. Add additional sensors, probes, and switches and monitor them on the screen!
    • Add safety by installing a backup camera. CTS3 contains a USB port and accommodates the simple install of Edge’s Backup camera.
    • Your factory speedometer is no longer accurate once you add larger tires. Easily add your new tire size and display your true speed through your CTS3 Monitor.
    • Ships with state-of-the-art suction cup and ability to work with Edge’s custom mounting solutions for that factory installed look.
    • WiFi and Internet updatable to stay up with future feature releases never missing out on the next big thing.
    Edge Insight CTS 3 Fits 2001-2024 Silverado/Sierra 2500HD/3500HD Part# 84130-3   THE PERFECT INSIGHT! Observe and understand your vehicle parameters using Edge state-of-the-art technology. Our Insight CTS3 delivers unmatched monitoring capability for any OBDII vehicle (1996 or newer). This digital gauge display works w
