working on a1948 diamond t truck. I installed an lml but converted to lbz injectors and ecm. The lml oil sensor thread is larger than the lbz sensors. I don’t have a complete pin out for the lbz. Should I cut and splice wires to lml sensor, drill tap oil rail plug to lbz thread or just leave sensor out. I do plan to tap a plug to 1/8 “ pipe for after Market gauge. Does the ecm need to see oil pressure. Looking for advice.
Lml to lbz oil pressure sender
Originally posted by Roger O’Dellworking on a1948 diamond t truck. I installed an lml but converted to lbz injectors and ecm. The lml oil sensor thread is larger than the lbz sensors. I don’t have a complete pin out for the lbz. Should I cut and splice wires to lml sensor, drill tap oil rail plug to lbz thread or just leave sensor out. I do plan to tap a plug to 1/8 “ pipe for after Market gauge. Does the ecm need to see oil pressure. Looking for advice.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Originally posted by DMAXDRHi Roger! I just put an LML block in A 2009 MMM. What I did was use a LML oil pressure sensor and connector pigtail . I cut the LMM oil psi connector of the harness and wired the LML connector to it. It works the same as your LBZ the terminals are just in a different orientation. I see about putting up the wiring diagram.
- 1 like
Originally posted by Roger O’DellWish you were closer, I could probably help you with the car
