Anyone with input on this would be appreciated. I'm going to do one since I broke my crank in September. I called to talk to Idaho Rob, but he was busy on the dyno and his staff would not pass my message on to have him call me back. Then someone else was going to call back and have not heard from him yet, that's only been four weeks ago, maybe longer.Kind of bummed on that, but oh well. Reason I wanted to talk to Rob was I know he's running one in his truck from Socal. Any loss of torque with this cam?
Alternate firing order cam
Dirtymax63
What is your ride going to be used for?
We are currently doing a engine build and the truck will be a daily and a track truck. We are using Socal alt. Firing order 6480 cam shafts that will support 1000hp and tow and daily. Pistons will need to have valve reliefs due to the higher lift of the 7480 and the 9100 cam profile provides. The guys at ATP also felt this was a good choice for our build. Let me know what your plans are and I'll help steer ya in the right direction.
DMAXSTORE.COM2006 LBZ Daily Driver, Tractor, School Bus, Hot Rod Diesel , Crew Cab, Lifted, Hunting Rig , Cowboy Cadillac
It's both daily an race
6480 didn't need piston valve relief was that correct? I'm looking at going to 1000plus and it is both daily and race right now. what about the torque with the alternating cam the same, more, less? If I end up having to take my heads off I will do 9100. I'm really looking to know if there is torque loss with the alt. cam?
The 6480 requires valve relief, we are running Fingers cast race oval bowl pistons with 75 tho. Relief. From what I understand the 9100 is drag/pull only not good for street or tow. I'd call Socal for exact info on their cams and dyno results.2006 LBZ Daily Driver, Tractor, School Bus, Hot Rod Diesel , Crew Cab, Lifted, Hunting Rig , Cowboy Cadillac
So... the information that I have gotten is that the 9100af cam will move the HP &TORQUE to a higher rpm. Was not able to get any numbers due to the manufacturer not giving them out and the many engine combinations. They don't recommend the 9100 for D/D or tow but people do. You will also need the .075 in valve pockets in the pistons as well as a torque converter matched to the new power range. Was told some of the negative feed back on these higher profile cams is due to incorrect combinations. Should have some low end power loss.2006 LBZ Daily Driver, Tractor, School Bus, Hot Rod Diesel , Crew Cab, Lifted, Hunting Rig , Cowboy Cadillac
