DMAXSTORE Offers Transynd Fluid & Service Packages For Your Allison
  • DMAXSTORE Offers Transynd Fluid & Service Packages For Your Allison
    Transynd Fluid and Service Packages
    Dmaxstore has put together these great packages for our members to correctly service their Allison transmission with the best fluid and the best filters. These kits provide the correct amount of fluid and spin on external filter for 2001-2019 Duramax diesel trucks.
    Tests prove that TranSynd™ will outperform other oils on every level:
    • Providing superior wear resistance
    • Extending drain intervals
    • Protecting other transmission components
    • Resisting oxidation and sheardown
    • Improving viscosity stability
    Gears, bearings, bushings, clutches, thrustwashers and other components benefit from improved viscosity stability and cooler lube oil.
    TranSynd™ heavy-duty automatic transmission fluid, a remarkable synthetic oil exclusively formulated by Castrol for Allison Automatics, extends Allison transmission oil drain intervals 300%.
    TranSynd's viscosity stability and resistance to thermal breakdown protect your Allison Automatic far better, far longer. And TranSynd™ is highly resistant to oxidation, minimizing chances for sludge and varnish deposits.
    You invested in Allison Automatics because you wanted your vehicles to be more productive, more profitable. New TranSynd™ transmission fluid not only protects your investment, it improves its return.
    How to get the best out of the best. TranSynd™ is a new, synthetic automatic transmission fluid developed by Castrol and specially engineered for Allison Transmission. It's specifically designed to make Allison Automatic-equipped vehicles even more efficient, more productive and more profitable to operate.
    Natural limits:
    Conventional transmission fluids have performance additives blended in. Performance additives include friction modifiers, anti-wear agents, antioxidants, dispersants, detergents, rust/corrosion inhibitors, seal swellers, anti-foamants and more.
    These other oils undergo physical and chemical changes with extended use. Physical changes include sheardown- permanent viscosity loss.
    Chemical change results from oxidation when oxygen combines with oil molecules to produce peroxides and organic acids. The oil thickens over and becomes more acidic. Sludge and varnish deposits erode shift quality and clutch durability and cause increased component wear.
    It's a vicious- and viscous- cycle. (Viscosity- the measure of an oil's resistance to flow at a given temperature- is the single most important physical property of automatic transmission fluids.)
    More than a lubricant:
    The transmission fluid doesn't just lubricate. It cools and transmits power, too.
    Time for a change:
    TranSynd™ automatic transmission fluid defies conventional oils- and wisdom. Its unique molecular structure produces excellent antioxidant properties. It contains none of the Viscosity Index Improvers which are added to other oils to maintain viscosity, so it doesn't sheardown.
    Consequently, TranSynd™ is more chemically and physically stable than other oils.
    Allison Service Package (Fluid & Filter)
    What is included:
    • 2 Gallons of Allison Transynd synthetic fluid- (We have found this fluid to be far superior to anything else available.) It is completely compatible with Dexron 3 and Dexron 6 designed specifically for the Allison transmission.
    • 1 genuine Allison spin on transmission filter
    Allison Deep Sump Package Deal
    What is included:
    • 1-Allison deep sump transmission pan
    • 1-Allison deep sump Internal filter
    • 1-Allison spin on external filter
    • 3-Gallons Transynd synthetic fluid
    Dmaxstore Note: If you you have an Allison deep sump pan you will need 3 gallons of fluid. Larger aftermarket pans will need approximately 3.5-4 gallons If you are dropping the pan to replace the internal filter you will use approximately 2.5 gallons on a standard sump pan and 4-4.5 for deep sump pans.
    Installation:
    • Remove 15 mm drain plug on transmission pan and drain old fluid, this should be 7.4 quarts unless you are low on fluid, or have a deep sump pan, reinstall drain plug.
    • Remove old spin on filter, remove filter magnet located on top of old filter and clean it with a rag. Install magnet on new filter and fill with Transynd fluid, reinstall filter on transmission.
    • Using transmission funnel fill transmission with 7.4 quarts of Transynd for standard pan and 14-16 quarts of Transynd for a deep sump pan and check level.
    • We recommend this service every 30-40 thousand miles to keep your Allison running its best. Allison does not recommend using a machine to filter or flush the transmission.
    Summer is approaching and towing those RV Trailers and just getting the DMAX on the road is great time to get a drain and fill done with Transynd and new filters.
      Great time to get out and service the Allison before you tow that rv or boat! Stay ahead of the heat!
        Reminder to keep up with your Allsion's maintenance as the summer heat and extended use of your duramax increases with pulling the boat, RV or other toys. Don't be sorry, stay proactive!!!
