One day I was driving around town and stopped at a light. When i went to take off from the light i had no farward gears only reverse. Took it to a shop and they said the tcm was fried. Put a new tcm in and still no forward gears. Next was a full trans rebuild including a suncoast converter. Still no forward gears. Just started replacing parts after that. Here’s the list of new parts: tcm, full rebuild, torque converter, valve body, pressure switch, internal harness, and nsbu. Still no forward gears only reverse. Need help. No codes.
2003 Allison no forward gears
Originally posted by Lb7pullerOne day I was driving around town and stopped at a light. When i went to take off from the light i had no farward gears only reverse. Took it to a shop and they said the tcm was fried. Put a new tcm in and still no forward gears. Next was a full trans rebuild including a suncoast converter. Still no forward gears. Just started replacing parts after that. Here’s the list of new parts: tcm, full rebuild, torque converter, valve body, pressure switch, internal harness, and nsbu. Still no forward gears only reverse. Need help. No codes.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Originally posted by DMAXDRSeems like C1 is not applying, was C1 clutch air checked when the trans was being rebuilt?
Originally posted by Lb7pullerOk im going to try to unplug everything tonight and see if i have 3rd gear or not. Thanks for the help.
