Time and time again, we get asked what should I run in my fuel and why.
Well, after only dealing with the duramax platform from day one, we believe the Opti-Lube to be the best all around additive for your duramax. Here are some of the blends and benefits for each. We have ran every blend, in our own trucks and the shop trucks, and they all have their individual benefits and we can say, for what Opti-Lube claims, they deliver!
![](https://dmaxstore.com/products/image/data/opti%20lube%20product%20table.jpg)
Features
Opti-Lube BOOST Formula
Winter Diesel Fuel Improver
Bennefits:
Opti-Lube XL Xtreme Lubricant is the ultimate lubricity additive with revolutionary deposit control.
This product continues to increase the lubricity of diesel fuel up to a mix ratio of 512:1. Proven Xtreme lubrication is also followed up with water and deposit control to keep your fuel system safe and functioning at its full efficiency.
Designed for use in Ultra Low Sulfur Diesel (ULSD)
Opti-Lube XPD Performance Blend
Part# OPT-XPD1GAL
Opti-Lube Performance Blend (XPD Formula) Simply the highest rated diesel additive on the market. One bottle contains 1 GAL. of Opti-Lube Performance Blend, enough for up to 20 fill ups!![](https://dmaxstore.com/products/image/data/opti%20lube%20product%20table.jpg)
- 1 x Gallon of Opti-Lube XPD Formula
- 1 x Dispensing Pump
- 1 x Refillable Bottle
Features
- Increased Power/50+ Cetane Boost
- Improved Fuel Economy
- Lubricates Injectors & Pumps
- Cleans Fuel System & Reduces Deposits
- Improved Cold Weather Starts
- Stops Fuel Waxing & Jelling
- Improved Corrosion Resistance
- Improved Fuel Storage Stability
- Improved Water Separation
Opti-Lube Summer Blend Formula
Part # OPT-S1Opti-Lube is the ultimate in performance diesel fuel additives Boosting Cetane is just the beginning, this product also improves efficiency, cleans injectors and lubricates fuel.Opti-Lube products protect your equipment by providing exceptional lubrication in the fuel system
Includes: - 1 x Gallon of Opti-Lube Summer Blend Formula
- Features:
- Boosts Cetane
- Enhanced Lubricity for Reduced Fuel System Wear
- Increased Power
- Reduced Deposits
- Reduced Emissions
- Prevents Rust & Corrosion
- Cleans Injectors
- Improved Storage Stability (More than doubles storage life of diesel fuel)
Part# OPT-B1GAL
Opti-Lube is the ultimate in performance diesel fuel additives Boosting Cetane is just the beginning, this product also improves efficiency, cleans injectors and lubricates fuel.Opti-Lube products protect your equipment by providing exceptional lubrication in the fuel system.![](https://dmaxstore.com/products/image/data/opti%20lube%20product%20table.jpg)
- 1 x Gallon of Opti-Lube BOOST Formula
- Maximum Cetane Boost
- Increased Power
- Reduced Deposits
- Reduced Emissions
- Cleans Injectors
Part# OPT-W1
Opti-Lube is the ultimate in performance diesel fuel additives.Improving Lubricity is just the beginning, this product also improves efficiency and cleans injectors. Cetane is improved by at least 3 points, fuel will flow down to -50°F. Opti-Lube products protect your equipment by providing exceptional lubrication in the fuel system.![](https://dmaxstore.com/products/image/data/opti%20lube%20product%20table.jpg)
- 1 x Gallon of Opti-Lube Winter blend
- 1 x 16 oz. and 8 oz. bottles
- 1 x Hanp Pump
- Increased Power
- Reduced Deposits
- Cleans Injectors
Optilube XL Extreme Lubricant
Part# OPT-XL1
- 1 x Gallon of Opti-Lube XL Extreme Lubricant
- 1 x Hanp Pump
Bennefits:
- Proven Xtreme Lubrication for safe fuel system operation & reliability
- Improved Fuel System Efficiency
- Reduces Deposits & Cleans
- Reduced Emissions
- Cleans Injectors
