DMAXSTORE Service Facility
  • DmaxStoreJake
    replied
    This LML was in for some maintenance today, just a quick fuel filter change and he is on his way! We installed a Genuine Parker Racor fuel filter, we recommend this filter for all Duramax trucks from 2001-2016.Click image for larger version
ID:	5513 Click image for larger version
ID:	5514 Click image for larger version
    Leave a comment:
  • DmaxStoreJake
    replied
    Customer came in to get a new rear differential cover, ended up needing a new ring and pinion. After taking off the rear differential cover we noticed some play and got an AAM replacement and put everything back together on this LML.
Name:	empte rear diff.jpg
ID:	5498 Click image for larger version
Name:	ring and pinion 1.jpg
ID:	5499 Click image for larger version
Name:	ring and pinion 2.jpg
ID:	5500 Click image for larger version
Name:	g2 rear cover-1.jpg
ID:	5496 Click image for larger version
Name:	g2 rear cover-2.jpg
    Leave a comment:
  • DmaxStoreJake
    replied
    Installed a Banks rear differential cover on a L5P that we lifted a while back.
    Leave a comment:
  • DmaxStoreJake
    replied
    We got a 2010 LMM Duramax in the shop looking to upgrade his fuel system. We installed a Titan 52 Gallon Fuel Tank along with an AirDog II 4G.
ID:	5485 Click image for larger version
ID:	5486 Click image for larger version
ID:	5487 Click image for larger version
    Leave a comment:
  • DmaxStoreJimmy
    replied
    LLY in for some TLC... Stage 5 trans, new XD UCA’s, and replace bearings and back half of the transfer case with a XD!
    Good as new!
    Leave a comment:
  • DmaxStoreJimmy
    replied
    One down...
    Other one is awaiting a new turbo then the motor can go back in and the body will go back on.
    Leave a comment:
  • DmaxStoreJimmy
    replied
    This week we are doing a swaperoo...
    Customer has a couple LBZ’s. Engine swap, cab swap, and drive swap (4wd being converted to 2wd and vice versa). If you can’t buy what you want but have all the parts, we can make it. The newer cab that is getting swapped to 4x4 will have a floor shift. Some pics of the progress.
    Looks like a Ford service facility with all these cabs up in the air....
    And one of them is starting to look like a truck again.
    Leave a comment:
  • DmaxStoreJimmy
    replied
    Our shop truck (LBZ) got fitted with one of our new Max-Flow Arctic Electric fans.
    Leave a comment:
  • DmaxStoreJimmy
    replied
    LBZ workhorse with over 300k getting a new lease on life. Headgaskets, ARP studs, new turbo, new CP3 and a new waterpump.
    Leave a comment:
  • DmaxStoreJimmy
    replied
    Got some new wheels and a new turbo setup on the race truck. She’s ready for Truck Mania this weekend!
    Leave a comment:
  • DmaxStoreJimmy
    replied
    Time for some motor mounts...
    Leave a comment:
  • DmaxStoreJimmy
    replied
    This truck is getting a new fuel system, CP4 decided it was done.
    Leave a comment:
  • DmaxStoreJimmy
    replied
    This LMM came into the shop on a flat bed. Owner wanted a second opinion after the local Chevy dealer supposedly ran return rates and a few other diagnostics and told the owner she had 8 bad injectors. We started a return rate test when we got the overwhelming smell of gasoline. Turns out all it needed was the tank drained, back on the road in no time and the injectors are fine. Duramax’s run better on diesel than gasoline.
    Leave a comment:
  • DmaxStoreJimmy
    replied
    Van with a duramax getting a little love had a 4x4 conversion and we installed a PPE motor oil pan and some Kryptonite tie rod sleeves. Notice the 4L80 tranny and not the Allison...
    Leave a comment:
  • DmaxStoreJimmy
    replied
    LB7 getting a new lease on life with some new head gaskets.
    This LB7 just finished getting put back together after getting all new injectors and high pressure lines.
    And this LLY got a brand new Garrett turbo and we welded the downpipe bracket on that hd cracked off the passenger uppipe.
    Leave a comment:
