DMAXSTORE Service Facility
  • DMAXSTORE Service Facility
    Click image for larger version  Name:	Dmax_SaleAd_2.jpg Views:	2 Size:	796.1 KB ID:	57
    Stay tuned for exciting daily updates with customer rides, projects and services going on in the DMAXSTORE Service Facility!
    I'd love to drive the black one. What's it's best 1/4 time currently?
      Ok, new day and new forum at the DMAXSTORE.
      Today in the service department we have a LB7 getting some serious mods, it will be a ultimate Sleeper bad A$$ truck, stay tuned for that.
      So this customer came into the DMAXSTORE with this LBZ he just purchased, with 37k original miles to get a complete look aver. Needless to say, the LB checked out like new!
      The LB7 was having some heating issues, will be getting a new radiator.
      And, a tow in, will update with the issues later
        12.2 I believe with stock bottom end and small injectors.. Its under the knife as we speak for a low 11 sec build
          So, the truck on the flat bed I posted earlier will need injectors
          Seems to be a theme for the LB7 owners, because this truck is getting them now in the shop
          then after this one is out soon, the black goes in and then this green one goes in for injectors
          and then this truck will get two heads, seems one is leaking some coolant (crack) so he is opting for two
            How long would it take your best suspension guy to put on a stage 3 kit, plus upper and lower kryptonite ball joints.
              We have been very busy in the service department and love working on all our customers trucks!! Just wanna say thank you to all our customers!!!
                Monday is upon us and we have 3 lb7 injectors in the shop under knife as we speak
                  also we have this work horse getting a water pump and one injector replaced
                  and this center bearing on a customers truck
                    This beaut of a lb7 is in with some fuel related issues. Getting a lot of pressure so an adjustment to the lift pump is in order and some more diagnostics.
                      So, the injector jobs continue along with this HD getting a leveling jit, Kryptonite UCA's and kryptonite Tie Rods and Cognito Pisk.
                      Update on the sleeper lb7 that got the PPE Manifolds and Up Pipes, DDP 100 HP Injectors and Stealth 64.
                      its done and running and it sounds great. Those DDP injectors are awsome. This thing will get it.
                        Go here to check out the build pic and video of the lb7 sleeper the DMAX STORE just finished for our customer
                        https://forum.dmaxstore.com/forum/ma...7-for-customer
                          Cranked those LB7 Injector jobs out and now we have a turbo swap for this customer
                          replacing with this 63 mm
                          then the DMAX STORE Dually getting some removal done
                          stay tuned for more form the DMAX STORE Service Team!
                            Here are some pics of the turbo going on the truck above from today
                              Just a nice easy steady day to day in the service facility.
                              Some standard diagnostics and maintenance routines going on with oil and filters and our tranny builder is busy building a trans.
                              But the fun stuff is the shop race truck. Getting the front end clip and components taken off cause the engine is coming out and the DMAXSTORE Built Motor will be going in!
