On the 2001-2007 GM transfer cases, models 136,146, 246, 261, 261HD, 263HD, and 261XHD all come with a magnesium rear cover which are prone to leaking. The pump housing is driven by the shaft and wears out the soft magnesium rear cover by wearing a hole, as shown below.
Click image for larger version  Name:	IMG_7665.jpg Views:	1 Size:	130.5 KB ID:	5280 Click image for larger version  Name:	IMG_7660.jpg Views:	1 Size:	137.7 KB ID:	5277 Click image for larger version  Name:	IMG_7661.jpg Views:	1 Size:	259.1 KB ID:	5278
The DmaxStore Transfer Case Upgrade Kit will alleviate this very problem by including a billet transfer case pump housing that is designed to distribute the force over a much larger patch than the OEM pump housing does. This will eliminate any worry of the pump housing wearing a hole in your transfer case. Here is the DmaxStore Billet Transfer Case Pump Housing.
Click image for larger version  Name:	IMG_7664.jpg Views:	1 Size:	139.2 KB ID:	5279
