Step 1:
Remove filter head from truck
Step 2:
Remove the 3 #20 Torx screws on the top of the filter. This is spring loaded use caution not to loose any parts.
Step 3:
Remove the first of 4 orings with larger Viton Oring provided in Dmaxstore Rebuild Kit. Reinstall pump cover with the 3 #20 Torx bolts.
Step 4:
Turn housing over and remove the 2 #20 Torx bolts. This housing is also spring loaded but will be slightly difficult to remove, us some upward pressure or flat blade screw driver.
Step 5:
Replace the second largest O-ring with Viton O-ring provided.
Step 6:
Replace third largest O-Ring with Viton O-Ring provided.
Step 7:
Replace smallest O-ring on bleeder screw with Viton O-ring provided.
Step 8:
Reinstall rebuilt filter head with New fuel filter from Dmaxstore and bleed fuel system.
Note: Please lubricate new O-rings for easy installation
This image has been resized. Click this bar to view the full image. |
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
Step 8:
